I am a maintenance technician for a retail store in Maryland.  We are building a cash register surround and I have a question on where I can place the receptacles.  The unit will be powered with two 20 amp circuits via SJ cord plugged into a tele-power pole.  From there it will have 12/3 MC running to the first two register stations then 12/2 MC running to the last two register stations.  My question is on placement of the receptacles.  I would line to mount 1900 boxes under the cabinets with a 3/4" device ring to bring me flush and use a stainless steel cover plate.  My fear is that this would be against code because the receptacles would be flush mounted on the flat bottom surface of the unit.  Is this a problem?
My other option is to cut holes with groumets and surface mount 1900 boxes on the side of the cabinets but this obviously would not look as nice.
Thanks for any advice!
