field made offset mud ring
A 4 square box is mounted as high up on a metal frame back splash Knee wall as possible. The Cabinets being installed come from China and are 35-1/4" high. there is a 3/4" plywood base under 3/4" granite. ounter top is 36-3/4" AFF. The top of the knee wall is 40-1/2" ( a breakfast bar will be installed on top of it to make the height of the breakfast bar 42".) Here is my challlenge
I have too many wires in box to use a deep 1 gang old work box.
What I am considering as a solution is this.
a 2 gang mud ring 5/8" raise. blank off one side therefore giving me an offset type mud ring. Also using a box extender to bring out thru backsplash which is 3/4" thick. Any thoughts on this solution? Or any other ideas?
Put a junction box in the cabinet below (flush or surface mount it, your choice) to splice the excess conductors in and only run one cable to the outlet box above.
I saw the offset mudrings from Garvin. My problem is time. Needs to be done yesterday. My only concern is; Is there any code that would not allow what I want to do?
They sell them at Home Depot (hopefully in yours)
This is the best idea, think out side of the box, and into another box. :roll:
NO
Is that material listed for the application you consider?
I'm sure it'll work, and I'm sure is not much of a hazard. But will not be UL listed, and as most AHJ asks materials to be UL listed, I doubt it'll pass inspection.
