jmarini328i
- CT
I have 2 question about simple wireing methods on recepticals to end an argument.
first question: In applications where mc and or romex, and all metel boxes are used. do you need to run a grounding pigtail from the ground screw in the box to the ground screw on recepticle? or is the 6-32 receptical screws "means of ground enough" for the receptical since all grounding conductors are bonded to the box via 10-24 green ground screw?
second question: does it say anywhere in the nec that you shall not use all four screws on the duplex receptical? Meaning using all the screws to continue the path of electricity in and out via the hot and nutral breakble tabs on duplex receptical.
