101116-1027 EST
Pitt123:
On your first question:
So at 4mA the transmitter sees most of the voltage (lets say 24V in this case) across its internal impedance or terminals and supplies very little voltage to the external of the circuit?
I want to change the viewpoint a little. The transmitter, when it does not include the voltage source, simply modulates the current flow in the loop. It does not supply voltage to the loop, but by its modulation of the current adjusts the distribution of voltage between itself and the loop resistance external to the transmitter.
Consider the receiver to be 250 ohms. Typically the receiver will have an internal resistor (current shunt) used to convert current to voltage to measure current in the loop. This is the reason the receiver has a substantial input resistance. Thus, at 4 MA loop current the receiver has a voltage drop of 1 V, as you said. At 20 MA this voltage drop is 5 V. This sensing resistance could be smaller, but for normal systems at reasonable voltages 250 ohms would be a maximum. If this resistance was dropped to 25 ohms and thus 0.5 V for full scale there would be no real problem because DC amplifiers today are readily available with noise levels in the 1 microvolt range. Even 2.5 ohms or 50 MV full scale would work.
Back to your question. Consider wiring from the transmitter to the receiver to have zero resistance. Thus, resistance external to the transmitter is 250 ohms. In other words put the transmitter close to the receiver. Assume a source voltage for the loop of 25 V and this source is separate from the transmitter. To produce 4 MA in the loop the voltage drop across the transmitter has to be 25-1 = 24 V. At 20 MA this becomes 25-5 = 20 V across the transmitter. The power dissipation in the transmitter is 20*0.02 = 0.4 W at 20 MA. This would be the worst case. Any additional resistance in the loop will reduce the power dissipation in the transmitter.
If the transmitter was to adjusted to 0 current, meaning it ceases to let current flow, then the maximum voltage across the transmitter terminals becomes 25 V. The internal output transistor in the transmitter in this current loop has to withstand this voltage. Probably a transistor with at least a 50 V rating would be chosen.
At the maximum current extreme, 20 MA, the lowest voltage drop across the transmitter will be determined by the sum of the lowest voltage drop across the output transistor and internal current sensing resistor. Suppose the current sense resistor is 1 ohm and an FET (field effect transistor) of 4 ohms drain-source resistance is used. Then the lowest possible resistance of the transmitter is 5 ohms. The transmitter can have a resistance anywhere from 5 to near infinity ohms. The minimum resistance is important in determining the maximum wiring resistance. With a 25 V source and 255 ohms minimum between the transmitter and receiver, and the need to provide 20 MA the result for maximum wiring resistance is (25/0.02)-255 = 1250-255 = 995 ohms. But then you need some margin and thus maximum wiring resistance has to be somewhat lower than 900 ohms. The purpose of using a current loop system is to eliminate errors from variation of resistance in the loop. For example temperature of the wiring.
So at 4mA with an external resistance of 250ohms we might only meausure 1V between the transmitter output and some common point int the circuit, or in other words 1V across the external 250ohm load?
I am not sure what is your question. In the external circuit (I have been including the voltage source in the external circuit) you have to define the points between which voltage is measured. So depending upon the points measured the voltage could be the 1 V across the 250 ohms or something else.
Does the analog output card on a PLC behave the same as a transmitter in that the output adjusts its internal impedance to supply the correct mA signal to the circuit? It will therefore adjust the voltage output as well. So even though the output card has a 24V supply, this ouput voltage will be adjusted to meet the current requirements of the external circuit.
If you are describing a PLC current loop transmitter with an internal voltage source, then yes. But I would rather say the device controls the current rather than voltage. Indirectly it adjusts the output voltage, but it does not measure output voltage and use this measurement for control. Rather it adjusts its internal resistance to achieve a certain current flow.
Note: This type of device can be described as an adjustable current source. Being a constant current device is only valid over a limited range of parameters. Some physical devices are inherently somewhat of a constant current source. Such as: a pentode vacuum tube, a bipolar transistor, and some designed circuits with many components in an integrated circuit.
