Instrument Signal Wiring Colour Codes
Hello Everyone,
Can anyone please tell me if there is anything in the NEC or anywhere else (UL etc.) that speaks specifically to the conductor color codes for +ve and -VE of instrument signals (typically 24VDC/4-20mA)? I have checked but have been unsuccessful thus far. I know that in the US the accepted practice is Black +ve and White -ve. I have looked at UL-508A but it seems that it is specific for control wiring inside panels.
Also any reference to the accepted practice in Europe (White +ve Black -ve) would be appreciated since this difference is the at the root of my issue.
It's all a bit confusing and causes some conflict since there seems to be alot left open to interpretation. Any help would be greatly appreciated.
Thanks.
In the 08 NEC-70 on pages 70-686, 687,688 there is a list of Product Safety Standards.
The following might be one in the same as the page above but more might be found here on, UL's WP reflecting a search for; Home > Industries > Wire and Cable > Standards; all based on USA usage.
You might try going to UL's home page and signing is as being in Europe and see if you can find a page matching the one above, just a thought.
250.119 would require the EGC to be green with a couple of exceptions.
White is the grounded conductor but when you work thru the rules, they don't apply under 50 volts.
White or Black to + or - it does not matter just be consistant.
You can also buy instrument cable with black and red.
