JWCELECTRIC
- Massachusetts
If it is still the same guy I had to deal with him twice and both times he was out of line.
From what I remember, He had the silver hair look going on.
I have to imagine it the man I meet has retired, he seemed older than dirt and that was 8 to 10 years ago.
What do you do to correct them? Do they all simply plant their feet in the mud and refuse to have an actual conversation about how and why they feel something you did was not in compliance with the minimum code standards?
When this guy told me "I like to see..." I stood there for a minute in silence and then just said "Why?". At which point he said "I'll let it go this time". had he insisted I do what he wanted I would have brought out the code book without hesitation.
After I get my final I'll be emailing him a list of relevant code articles for his reading pleasure. I'm sure he'll give a crap. :roll:
I dealt with that guy around the same time if not a couple of years prior. "I want two receptacles per circuit" "I want green wirenuts, no crimps" blah blah blah... :roll:
The way to deal with inspectors that do not know the code is complain to his boss. And i mean ride his case hard and get all the others to do the same. If he is out of line often enough and you complain loud enough his boss will get sick of the phone calls and will have a long talk with him. Most inspectors do not fall into this area but doing nothing will not change his ways. Let him know that every time he makes a wrong call that he will get called down. End result is he will be very careful about what he tags you on. Demand he site code numbers on each and every violation he writes. It works and I have done it.
As far as what the OP ran into might very well come down to what the permit was for.
Replace cabinets and counter tops to me is not a remodel but if contractor called it that on permit then we might be close to the problem. What else was done to the kitchen that might change what this job is called ? New floor covering ? Repaint ? New appliances ?
If you can afford $10,000 to put in new cabinets and counters, I'm pretty sure the couple hundred bucks for GFCI receptacles to be where they're supposed to be, isn't going to break you.
Nothing personal but that coming from an inspector makes my hair stand on end.
It is not your money, or the states money to decide what to do with.
