quinn77
- Lake Jackson, TX USA
ok...im having a little trouble trying to decipher this one.
200 amp 1 ph service located at detached garaged (attached with breezeway)
200 amp panelboard in garage contains 2-100amp cb's feeding 2-100 MLO sub-panels inside dwelling.
service GE is 3/4" by 10' ground rod.
If i am reading 250.104 correctly, must i run #4 bonding jumper from hot and cold ( no gas ) unspliced to the service panel to the ground rod?
thanx
thanx
