Eddy Current
Does anybody no a code reference for this? I no its a no no and can cause interference.
			It is not a code issue and it is unlikely to cause any interference.
yes it is a code issue 800.133
I know that it causes interference in fire alarm cable wouldn't it in telephone and computer cables. I also know that in audio it can cause some undesired static.
So there is no code? Is it just bad practice then?
I also came across this
http://www.neca-neis.org/cqd/index.cfm?fuseaction=showArchiveQuestion&id=2877
What fire alarm system do you speak of?
Just to note, that article you noted does not address the OP question. You were asking of the same chase. This is a very common practice with no ill effects in all but the most unusual situations. The separation of light and power circuits in raceways, enclosures and cable trays is important from a safety standpoint, but not interference.
A fire alarm guy told me once that fire alarm cable strapped to emt conduit and run through the same chase causes interference. Is this not true?
