Nium
 - Bethlehem, PA
I need a better lamp or at least one that has a longer life span.
Privately owned retail clothing store. At the dressing room area there is a large custom made light fixture. It consists of 18 squares. Each square is approximately 2.5' x 2.5'. Each square has 2 A19E26, 4 G16 E12, and 6 G12 E12 lamps. The lamps hang inverted at the end of rods 12" to 18" in length that terminate into the lamp socket leaving the naked bulb at the end of the rod.
The issue is that the 10W G12 and 15W G16 lamps are only rated at 2500 hours. A19's I can find with a slightly longer life. The longest burning lamps I've been able to find are at a max of 3000 hrs for the globes. Which means these lamps are changed out from 2 to 3 times a year (burning for 6 days at about 10 hours a day). Aesthetically since the lamp is exposed, spiral CFLs and heat sink base LED's typically aren't appealing.
Any suggestions as to a longer life G12 and G16 lamp would be greatly appreciated. LED suggestions are welcomed as well as fluoro. They want globes though which has been really limiting in my search for a longer life lamp.
