10amps vs 100amps contact resistance tester
vinod
Saudi Arabia
Gentlemen,
Why the Elec. Technicaian using '100amps' contact resistance tester instead of '10Amps' tester to test 3000Amps bus bar connections?
Can anybody give an explanation for this?
It is a matter of accuracy, the higher the test current the more accurate the readings will be at lower readings. A 3000A bus connection will have a very low reading so accuracy is important.
