- Chapel Hill, NC
- Retired Electrical Contractor
Just to add to my post above. Article 250.120(B) is about EGC so I am not sure when that would terminate without a JB. There is more to this then so are seeing, I think.
I suppose so. Until its actually terminated or spliced, it serves no purpose.
Using your logic the box would need to be 36+" wide.
Less than 6" (or the 3" variation) is only a violation if you terminate or splice it.So since it is not terminated I could leave only 1" of conductor in the box and be code compliant?
In reading the exception how would you explain a conductor terminating at an outlet. Use 100 definition for outlet.
