How many seimens 1 pole breakers can you tie together
Jd50
New member
Does anyone know if seimens breaker ties (ecqth3) are approved to tie more than two breakers together?
JD, welcome to the forum! :)
For manual disconnecting, a handle tie is adequate, so two or three 1-pole breakers may be joined with a handle tie for multiple line-to-neutral loads.
For automatic operation, as in over-current tripping, an internal common trip is required, so a "real" 3-pole breaker is required for a line-to-line load.
