2011 nec 314.28e
DPW
FT. SMITH, AR
It my understanding that this revised section will require power distribution blocks to be installed with a cover.
Does this mean that terminal blocks (120vac) mounted in a standard 4X4 box would be an exception or does the enclosure have to be over 100cu in?
If an additional component such as a fuseblock was mounted in the jbox, would it require an insulated cover as well?
That section applies to distribution blocks installed in boxes larger than 100 cubic inches.
A 4x4 cbox is not larger than 100 Cubic inches so it does not apply to them.
Chris
