Electron_Sam78
 - Palm Bay, FL
Thats code in mount vernon IL:grin:
We have an AL wire manufacturer here so it keeps the business going :grin:
We have that identical problem. Stainless motor-starters on our HVAC gear. The air-handler is a ball of rust but the motor-starters still look brand new....Along the same line I have seen $40K rooftop HVAC units have SS discos mounted on them, but the entire HVAC unit was ordered without corrosion resistant treatment, like epoxy coated condenser fins, so the unit will rot away before the $3K disco....
I've posted it here before, but my favorite was the guy who'd read the code article requiring a receptacle for every space 2' or larger on a kitchen counter. He interpreted it as a receptacle every 2 feet, so that's what he had: Kitchen was probably 10'x10' and had 17 or 18 GFCI's in it.
-John
-John
An average two-car garage with a receptacle on every stud. A past owner had a wood shop with lots of small equipment. I didn't open up the walls but he had told the neighbor that he always wanted to have power available no matter where he was working. The neighbor asked (jokingly) "is everyone of those on it's own circuit?" No, the owner replied, that would be silly. Instead he wired them in pairs, each on a circuit with the one directly on the opposite wall....figured he could never be on both sides of the building at the same time and could therefore never overload a circuit.
42 receptacles, 21 breakers, and a ton of romex.
PVC glue between fixed points in a climate controlled area. :grin:
. . . overkill . . .
equipment grounds in emt/rmc
Glenn77is,
That sounds like a dream job to have had.![]()
