All good replies, but can anyone answer the question if plug and play connections are allowed in modular built homes in the scenario described?
Thanks.
c
If this home was UL listed as a package deal then this is a question that only the manufacture can answer, about 50 miles east of me is one of the largest areas of manufactures of single wide, double wide HUD manufactured, and UL listed modular home manufactures (not to mention RV's) in the country, I have done everything from total installs to many different kinds of hook ups to these homes, The main difference between a UL listed modular and a HUD manufacture is the rules they are under, a HUD home will have a red plate attached to the outside of it, as was said the frames stay with it, while a modular will have a UL listing sticker at or by the main breaker panel, and the frame goes back to the factory, another this that is common is the outside walls of a modular are the same as a stick built 8' while a HUD manufactured home are only 7'.
Here in Indiana a UL listed modular is treated in the same fashion as a HUD home, if it carries the UL label its hands off to an inspector (except the field wiring such as services)
This is why I said you must contact the manufacture as they are the ones who will know what is in their UL listing, when I find code defiances, we report them directly to UL so they can make corrections with the manufactures and get them into compliance, if a HUD home has code defiances, we report them to HUD.
The plug in quick connects are part of the listing of both types of homes, and have been in use for the last 10 years around here, the only suggestion I have is to use a good dielectric grease on the connection to seal out moisture, in doing this I have yet to ever have one fail, these quick connects are UL listed in all the ones I have seen.
I will try to find my PDF from UL on modulars and post it, I have all HUD's codes if needed just PM me.
