jmd445
- Hamilton Twp., NJ
This isn't NEC related, but confusing. I'm scratching my head bald......
My daughter bought a new hair straightener at college. It worked fine. She came home for the holidays and the straightener worked intermittently. I had her exchange it for a new one. Last night she used a blow dryer, unplugged the blow dryer and plugged in her hair straightener. It DIDN?T WORK!!!
This circuit and receptacle serve other items in her room that operate fine, TV, DVD, radio, etc.
The straightener has a GFI as a plug. We tried several more receptacles in the house. Finally we found one that it worker in.
I have a push-matic 100 amp panel. Everything in the house works fine. The receptacles she tried were off the left buss, the ones it worked on were the right buss. I pulled my trusty Fluke and checked the polarity of all receptacles that the straightener worked in and didn?t work. All were 126.9 volts and 126.8 volts, very well balanced, all grounds and neutrals were fine.
After I checked all receptacles, I had her try her straightener where it didn?t work and now it works in all the ones it didn?t work in before. Some are ground up, some are ground down and some are horizontal.
When you reset the plug GFI, are they position sensitive?
