jxofaltrds
Retired ESI
- Mike P. Columbus Ohio
- Creator
Does 210.52(B)(2) prohibit a 120V receptacle outlet behind a free standing range?
			Uh...... no.
In our last thread I was told that it was prohibited.
Not by me.
Yes. It says no other outlets, and then provides an exception for a receptacle serving electric needs on a gas range (just gas).
There is no exception to allow general purpose receptacles on a SABC circuit behind a range.
Correct it allows that outlet. Does it prohibit me from having it there on a 'spec home'?......
There is no such thing as a 'spec home' in the NEC. It's a dwelling. Spec... custom...tract.... all the same to the NEC.
You know what I mean.
So I am not allowed to put both a gas and electric supply for a range in a home?
Installing both is perfectly legal. Heck if you wanted, you could legally install 24 120v recepacles behind you range if that's what trips your trigger. But they're not required for an electric range. Nor is a 120v recep behind an electric range prohibited.
Then you must have read all of our last thread.
Irrelevant.Correct it allows that outlet. Does it prohibit me from having it there on a 'spec home'?
It is. 210.52(B)(2) prohibits it.I do not need an exception unless it is prohibited.
Ken, the problem is it's not just any old 120V circuit, it is a SABC circuit.Installing both is perfectly legal. Heck if you wanted, you could legally install 24 120v recepacles behind you range if that's what trips your trigger. But they're not required for an electric range. Nor is a 120v recep behind an electric range prohibited.
Let's mess with your hypothetical home after a while. Agreed?You know what I mean.
Read it? Shoot, I think I wrote half of it!
