Yoke serves as the ground point. Remember the little green wire with the spade terminal that was supposed to go under the plate screw?Just noticed that today. Maybe I'm missing something??
I don't remember seeing any 2/prong receptacles with ground screwsJust noticed that today. Maybe I'm missing something??
I bet they use the same yoke for both receptacles rather than change. Surprised they would put the screw in but it may be cheaper then changing the production.
Why does a two prong recepticle have a ground screw?
About the only time an equipment ground is present where a two wire receptacle had been originally installed is where a metal raceway was serving the receptacle installation and was a complete raceway back to the point where the circuit originates.
"I don't think so, Tim!"The same reason men have nipples.Why does a two prong recepticle have a ground screw?
I like the same yoke theory also. I just can't magine that a production run would leave in the screw. It seems small, but that is real $ in large quantities.I bet they use the same yoke for both receptacles rather than change. Surprised they would put the screw in but it may be cheaper then changing the production.
What is a two prong "recepticle"?
It is this.
Thats a receptacle.
JX,
Got to read the posts more closely, man.
You missed something there.
That is a "Two Prong Recepticle"
with attachment for a "Non-Metallic EGC". :grin:
Electrical jargon very's around the country
I was having some fun. If it was not for spell check I would misspell recepticle all the time.
Have you ever noticed that I use recpt a lot?
I thought your comment meant that a receptacle has slots, I guess the prongs are inside.I was having some fun. If it was not for spell check I would misspell recepticle all the time.
