210.52(b)(2)
Can someone tell me where the wall behind a not fastened-in-place range (gas, electric or otherwise) is not to be considered as wall space, or something other than wall space, in the determination and application of 210.52(A)(2)...???
I was trying to keep that discussing here:
http://forums.mikeholt.com/showthread.php?t=132197
Does this help anyone?
Dennis is correct again.
Now note that it refers to Figure 210.52(C)(1).
I do not see a free standing stove there.
That discussion is taking place here.
Does 210.52(B)(2) prohibit a 120V receptacle outlet behind a free standing range?
Ken, the problem is it's not just any old 120V circuit, it is a SABC circuit.
The title of this thread is 210.52(B)(2).
I think the original question should have mentioned SABCs in it - that was the point of the previous conversation.
Ken, I am saying that 210.52(B)(2) prohibits installing a SABC receptacle behind an electric range. Agree or disagree?
Disagree. It is still wall space as I see it, and I don't know of any specific prohibition other than if it is knowingly going to serve something other than a small appliance (and that's the reason for Exception No. 2... because the equipment mentioned therein are not small appliances) .
I disagree. I can put a receptacle behind a range, power it from a SABC circuit, and use it to serve the countertop. This would not violate the ?no other outlets? rule.
Regarding 480Sparky?s post # 32, I would not need to pull the stove out, in order to plug in my toaster. I can simply reach the toaster?s cord over one of the burners. OK. That is a really bad idea, and a really, Really, REALLY bad design. But it is not, Not, NOT explicitly forbidden by anything in 210.52.
Regarding Dennis?s post #39, the exception tells us that we are not required to put a receptacle there. It does not command us to avoid putting receptacles there.
I totally agree and that is why I posted it. It states it shall not be required... this is not a prohibition.
