Greg1707
- Alexandria, VA
- Business owner Electrical contractor
I had an unusual situation.  In order to work on a 240 volt circuit, I turned a two pole Federal Pacific breaker to the off position.  The circuit remained hot.  I checked the terminals on the load side of the breaker and they were hot.  I had to remove the breaker to work on the circuit.  I replaced the breaker.
I turned this breaker on and off several times to no effect. Is this possible? Is it possible for a breaker to not break the connection when in the off position?
