Jim W in Tampa
- Tampa Florida
Yup.
It's the same as PV installers who use "welding wire" for battery connections instead of whatever the actually required wire is. Works great, doesn't seem to be a hazard, still not the correct wire.
But if your a residential electrician and on trim need to hook up the condenser and do not have thhn/thwn on truck and your boss pushing you to trim it today cause it is called in for morning inspection you just might do it. If inspector catches it then eat a red tag
