I am looking at a job that involves replacing a couple of roof top units. The existing wiring is #1 THHN running from the panel to each unit protected by 150A breakers.The new equip will be(per manf.cut sheet) minimum circuit ampacity 120A, maximum OCP 150A. Can the 90degree rating of the #1(150A) be used in this application or do I need to pull in 1/0 conductors to achieve the 150A @75 degrees? Thanks.
