I can't find in the code where the derating factors are located for multi layer runs or specifically cable on a reel. (SO cord, temp ratings, etc.)
I can find derating factor info on the web, just not in the code. Anyone know where this info is located in the 2008 code?
Does the code point to vendor derating info? (Same approach as in mining...?)
You can also contact me directly.
{Moderator's note: Removed email address. Use a Private Message to contact the OP directly.}
