No but the walls are:
http://www.awc.org/Publications/dca/dca3/DCA3.pdf
R502.13 Fireblocking required.
Fireblocking shall be provided in wood-frame floor construction and floor-ceiling assemblies in accordance with Section R602.8.
R602.8 Fireblocking required.
Fireblocking shall be provided to cut off all concealed draft openings (both vertical and horizontal) and to form an effective fire barrier between stories, and between a top story and the roof space. Fireblocking shall be provided in wood-frame construction in the following locations.
1.   In concealed spaces of stud walls and partitions, including furred spaces and parallel rows of studs or staggered studs; as follows:
1.1.   Vertically at the ceiling and floor levels.
1.2.   Horizontally at intervals not exceeding 10 feet (3048 mm).
2.   At all interconnections between concealed vertical and horizontal spaces such as occur at soffits, drop ceilings and cove ceilings.
3.   In concealed spaces between stair stringers at the top and bottom of the run. Enclosed spaces under stairs shall comply with Section R311.2.2.
4.   At openings around vents, pipes, and ducts at ceiling and floor level, with an approved material to resist the free passage of flame and products of combustion.
5.   For the fireblocking of chimneys and fireplaces, see Section R1001.16.
6.   Fireblocking of cornices of a two-family dwelling is required at the line of dwelling unit separation.
FIREBLOCKING. Building materials installed to resist the free passage of flame to other areas of the building through concealed spaces.
