knoppdude
 - Sacramento,ca
Hello everyone, I was busy working at the plant today, thinking everything was ok, even though it was raining heavily.  I walked by the office trailer, where a new service panel had been installed, with feeder exiting the top, through the ceiling space, then out to a panel.  I installed this, and was told to use a compression fitting threaded into a hub, as this was company policy.  kThe conduit is 2 inch emt.  Just on a hunch, I opened the panel, and sure enough, water was entering through the fittings.  Same with the Main.  I siliconed around all threads, which has slowed down, if not stopped the flow.  Definitely not a good situation.  I told the plant manager about this, and that when I can, I will reroute the feeder under the building, and use a sealing KO on both the main, and the panel.  The voltage is 120/240, but this situation still worries me.  Has anyone had a similar situation, and what was the long term outcome.  It will be raining for at least another week, so I might just start the work on monday, and hope for the best.  Thanks
