transformer ratio?
The Roc
I was wondering if anyone can help me ,does anyone know what the ratio in a transformer from primary to secondary , 1 : 4 ? thanks
It can be almost anything.
Care to be more specific about the transformer you have in mind?
it was a question on my exam ..
if the the primary on a transformer turns 40 times , how many times does it turn on the secondary, that all i remember... thanks..
Roc, welcome to the forum! :)
The turns ratio determines the voltage ratio. With a 1:4 turns ratio, the secondary voltage is 4 times that of the primary. The voltage varies proportionately with the turns ratio, and the current varies inversely with the turns ratio.
A 1:4 transformer with a 120v primary (when actually fed with 120v) would have a 480v secondary voltage. However, for each amp the secondary supplies to the load, the primary current requires four amps from its supply.
