didn't they come out with some paint that is supposed to do that?
Important note about conductive paint and the National Electric Code:
The is nothing in the NEC which prohibits painting your walls with conductive paint. However, because this product does NOT carry a UL listing, some electrical inspectors, by virtue of being the “Authority Having Jurisdiction” can require the homeowner to hire an electrical engineer to certify that the product is safe to connect to the electrical ground. They can also require that a licensed electrician perform the ground connection. If your application requires an electrical inspection AFTER installation, you should check with your local inspector BEFORE you proceed to avoid any surprises.
Well using an active blocker or jamming device is illegal, however using passive methods is legal. I do not know of manufactured products to do the job as I have never had a need to look for them, but it can be easily done during a remodel of initial construction by using a wire mesh screen or even chicken wire enclosing the room and bonded to the electrical ground or even the rebar in a concrete pad. The screen material is attached to the wall studs and ceiling joist before the drywall is attached.
The other way I know of works real good, use a steel fabricated building with steel siding and roof.
I havre also heard there is a metallic paint on the market made to do just what you want. Here is a REFERENCE LINK
No, from experience back in my RF engineering days building RF test cages.Did you find that here: http://answers.google.com/answers/threadview/id/413500.html ?
Chicken wire would be more than adequate as it is a function of 1/4 wavelengths. The two frequencies of interest with respect to cell phones is 800 and 1900 Mhz. Since 800 is the lowest frequency and longest wave length is all that has to be dealt with. 800 MHZ 1/4 wave length is .09 meters or 3.6 inches. Chicken wire mesh is considerably smaller and will cut off frequencies 200 Mhz and up.I doubt chicken wire has the proper mesh size to work, but maybe it does...
Unless it is me that is trying to rely on them.....Digital comms can get through some amazingly adverse conditions.
But as K8 MHZ points out any wiring leaving or entering the room will re-radiate signals inside the space unless measures are taken to divert the energy to ground. I agree with him this should only be done by an engineering firm with experience doing this kind of design.
Yes I understand that, brute force will penetrate. Cell towers operate depending on number of calls in place from 1/2 watt to 20 watts per carrier down link. Cell phones max power is 1/4 watt uplinkNO frequencies will be cut off.
The best you can get is attenuation.
EDIT: I would like to add that I know enough about radio to be able to design a room that is 90 percent effective and would NEVER do it for pay. I also know enough about radio to be able to defeat 90 percent of 'cell phone proof' rooms and would still never design such a room for pay.
The liability is too great and there is no way to be able to know for sure your design will work on every cell phone or wireless device there is.
A jammer inside of a mostly shielded room may work and perhaps not be illegal.
A few other ways to beat cell phones in conference rooms.
As far as #3, I have actually been in meetings where this was done as back charges at the end of the job. One sub-contractor was up around a grand after the job meetings came to an end.
- Have spot lights that will zoom in on the person getting the call so that all the others will get a good look at the offender.
 - Stop the meeting or conference and tell the others that the meeting or conference will resume when so and so get's done talking to who ever is more important than the others attendees time
 - If the attendees are contractors or sub-contractors charge them $100.00 for each time their phone interupts the meeting or conference.
 - Have all parties leave their phones in their vehicles or at the reception desk.
Roger
Me too.Good point. You should be able to jam signals in your own space.
It makes me wonder what happened to good manners.
I've even heard doctors say that patients will answer phone calls when the doctor is talking to them. And we've all seen people hold up a line at a check out talking on their phone.
Me too.
If I were a doctor performing the right exam I'm sure I give the party on the other end a scream from the patient.. :grin:
Roger
If they manage to be on the phone during that exam I'd be impressed.
