- Massachusetts
I happened to see this today and thought of this thread
As my father used to say," A thing of beauty, is a joy forever." :grin:
That's pretty typical of commercial work around here. I have no problem with it. It's meant to be functional, not beautiful. Nobody cares what electrical stuff looks like other than picky electricians on forums.![]()
I'm all for functional, but I can still get a laugh at it. :grin:
I can assure you a job like that is all about cost and not beauty.![]()
Typical retail commercial work is not good for the electrician who likes to make art work out of everything.
The bundled & melting MC cable would be the cause of everything falling in the first place.At least the MC will be safe. :grin:
Roger
Knowing what I do about the design of building the picture was in I would be surprised if any of those cables have more than 10 amps of load and many will be in the 1 to 4 amp area.
Sounds like a job for a 20-amper. :grin:Knowing what I do about the design of building the picture was in I would be surprised if any of those cables have more than 10 amps of load and many will be in the 1 to 4 amp area.
I missed that exception to derating in the NEC.Knowing what I do about the design of building the picture was in I would be surprised if any of those cables have more than 10 amps of load and many will be in the 1 to 4 amp area.
I missed that exception to derating in the NEC.![]()
Well, okay this time.Many of those cables will be fused between 3 to 5 amps.
They are not the best choice and after many years in a hot wearhouse you might have problems when they get brittle.
I've found the black UV-stabilized ones are fine, it's the cheap white ones that give way. And using a big enough one, of course. If you're really worried about it, get the stainless steel cable ties.
Now if I could only get people to trim them flush. Can't count the number of little scars from badly-cut tywrap tails. (Once caught someone "trimming" by cutting the tails down to an inch or so. Asked them "What's the point?" Didn't know. They received a bit of "supplemental training".)
