electricmanscott
- Boston, MA
- Massachusetts Master Electrician, one man show.
I would bet very valuable things that Don is not wiring houses.
			I would match that bet that if he did, he would pipe it in EMT; and you're darned right he'd use metal boxes.I would bet very valuable things that Don is not wiring houses.
What about EMT and metal boxes?In my book,
Good= NM and plastic boxes
Better= NM and metal boxes
Best= AC or MC and metal boxes
If you are a decent salesman and do a lot of customs or McMansions the upgrade should not be hard to sell. If you do spec forget it.
-Hal
In my book,
-Hal
to the person paying the bills, is there a difference between value and perceived value?Is the title of the book "wasting money on perceived value upgrades, a tale of nonsense" ?
You could go the Mr Hainey route and suggest for a slight increase in cost Metal boxes would most assuredly be used. . .. ... A job that has this kind of quality components should have metal boxes because it would enhance the craftsmanship needed to display the high quality materials of such a project....
and for just a few dollars more this all could be yours. What would it take to get you to upgrade to those sturdy metal boxes. Nothing lasts longer nor holds up better in high traffic areas like steel. They can come in metric sizes to accommodated European styling and added value of accommodating hard wired switches and receptacles in Almond the fashion color of the season.
If you consider these special order items maybe you might want to have the fine craftsmanship and professional installation of a piped in system with galvanized Electrical metallic tubing and epoxy coated interior for the smooth insertion of those very special and colorful wires lubricated and glistening with only the finest imported gels.
Pause here and look wistful ...
Just a small price for such a large increase in the expandability of your very personal and private space which you use to start everyday of your very busy lifestyle. Think of the added value of having both metal boxes and piped in wiring with individual wires to satisfy the safe and incredible good taste of such as yourself. This type of install is not for everyone. Please choose wisely. But in my humble opinion this installation is right for a person of your impeccable tastes. How much value do you place on your safety and the safety of your loved ones. Metal boxes, EMT, Special wiring, you deserve nothing less.
The use of EMT in the Chicago area is required by local codes. Those code cover about half of the population of Illinois.What about EMT and metal boxes?
I would love to do a whole house in EMT. If you could get them to pay for it go for it. Big selling point is the ease of wiring changes. I believe we had some pictures posted here several years ago by an EC in the Chicago area of a new construction rough he did. Pretty awsome.
-Hal
I have seen these at a Womack location. Womack has them as standard counter item. A good product.I can't find a pic right now, but, I've seen a two-sided nail-on box that's 4.5" deep and takes devices on both sides.
I've seen very little of this in houses. I've seen far more of a metal box with BX cable. I've seen lots of FMC in offices, etc. used down the walls.I agree that plastic is the cost and time effective way to wire a new house, however I spend much of my time on rewiring houses from the 1960s and I love it when I work on a house with metal boxes with FMC. It makes the rewire job so much easier and avoids having to rip up the drywall. When pulling a new groundwire on a two wire run or adding an additional circuit, the metal conduit and metal boxes makes rework a snap.
This is the primary reason I favor metal boxes and FMC. Maybe it doesn't make sense to consider rework, but I think it is worth the added expense.
