B4T
- Long Island, N.Y.
They do make 3" deep plastic boxes if you think that a dimmer might melt a standard box.. :roll:
Generally, my only use of metal boxes in houses is for dimmer switches, as I saw on other posts here, they help to heat sink some overly hot dimmers. I sometimes use them to gang up what I can't buy in plastic.
Plastic is cheaper, lighter, easier to nail up, don't have to tape terminal screws, etc. The few customers that have asked me, I've told them plastic has been standard for over 20 years. I agree with most previous comments about better space and grounding as well. I do notice that some of the speedlock or "quickclick" boxes don't securely hold device screws for a sturdy install. Sometimes have to up them to 8-32 screws. The ones without quickclick hold well, but are often a tight go with a screwdriver. Sometimes I even drill a 6-32 tap into them to loosen them up.
I do use metal for anything surface mounted on a porch, utility room, etc. where physical damage is a consideration.
I cant' imagine doing a house in EMT, as the Chicago guys posted. My cousin's apt in Chicago was wired in NM, what I saw in her attic. Older building though, in Irving Park area. Don't know when EMT became code there.
It is just like an Office bulding that is speced out for all EMT and Rigid You run the pipe inside the Rough walls,
in a house you would do it the same way smaller scale and of cource you would have wood studs instead of metal studs.
If you can the next time your roughing out a house do one room in pipe just for kick's:grin:
It's not that simple. In a house there are turns that need to be made that are really tough to do with pipe simply due to it's inherent physical limitations. There are other issues as well, but it's way easier to run EMT in a commercial building than in a wood frame house, and I speak from actual experience.
I know to do it. But in a cutthroat market, few would be willing to pay for it.It is just like an Office bulding that is speced out for all EMT and Rigid You run the pipe inside the Rough walls,
Given conditions are the same other than steel or plastic box, the steel box will dissipate heat better. Dissipation is directly related to the material's thermal conductivity. I don't know of any plastic which conducts heat better than steel.I agree i read somwhere that the plasic boxes disapate heat better.
Where steel boxes get hot as well as the dimmer switches.
Then you have the wire-EGC-vs-EMT debate.But it would be fun just to pipe in a room just for kicks if you have the time.
There was a post that said the non-metallic box would be a better heat sink.I've never heard of the "heat sink for a dimmer" argument in favor of metal boxes before now. There must be at least a billion dimmers installed in non-metallic boxes. I think that kind of reasoning is limited only to electrical forums.
Aren't all plastic boxes 1 hour rated now-a-day's?
It isn't that the box will melt, it is to transfer heat from the dimmer to the box keeping the dimming out put device from over heating. Like the fins on the front if reduced to fit you need to derate the dimmer.
If plastic was better then wouldn't the fins be made of plastic?
I've had customers complain about cover screws getting hot at dimmer switches 1/2 a billion times, they must have called someone else the other half.I've never heard of the "heat sink for a dimmer" argument in favor of metal boxes before now. There must be at least a billion dimmers installed in non-metallic boxes. I think that kind of reasoning is limited only to electrical forums.
Smart is correct, there is no way that with everything else being the same that a non-metallic box would be a better heat sink than a metallic one.
