masselectrician
 - Mass
Does any know if the NEC prior to the 2002 required the grounded conductor to be switched when using a generator and transfer switch?  Thanks
			I am not aware of any older code requirement that required the grounded conductor of a generator to be switch with the transfer switch. As far as I am aware this has always been a design issue not a code issue.
Chris
