M4gery
I have a lot of older houses in my area with plaster on wood lath.  My method has always been to use a Rotozip with a tile bit to cut out holes for boxes.  This is VERY dusty, having a vacuum there helps keep the dust down but some dust still escapes.  The tile bit also burns the wood lath quite a bit so most times I switch to a wood bit making it a two step process.
I was thinking about trying out one of those oscillating tools like the MultiMaster/Sonicrafter/etc. However, I did a small bit of research and found no blade specifically made for plaster (or tile).
Does anyone use this type of tool for plaster and wood lath? How do you like it? What blade do you use and how many cuts do you get?
If anyone has another method for cutting plaster on lath, I am all ears.
Thanks for the input.
