Since you are not differentiating between X0's I presume that you are refering to the wye point in the secondary windings and I further deduse that you are talking about a standard Delta/Wye trasnformer, especially since you not identified teh primary as 480/277V. There would be no reason to run a neutral to the trasnformer, nor would be any reason to land a primary source conductor on the secondary side windings.Friends, Given a tfmr 480 volt primary / 120/208 volt secondary. If you connect a neutral from the primary source to XO and the neutral from the secondary (load) to XO what effect would it have on the circuit?
250.24(a)(5)don, what code article are you referencing?
Thanks for the help, lyle![]()
Lyle
Are you just curious because you would not need to do this or want to do this
as per the other posts.
