natfuelbill
Does the NEC and OSHA provide anywhere for allowing a hazardous fluid into an area prior to pouring of sealing fittings? *Where?
The NEC does not speak to the issue directly; however, various Fed or State Process Safety Management (PSM) rules will address worker safety in most cases where hazardous or toxic materials are used. In this case ?hazardous? means more than ?explosive.? As often is also the case here, specific application details of the installation need to be known since there is no general answer.Does the NEC and OSHA provide anywhere for allowing a hazardous fluid into an area prior to pouring of sealing fittings? *Where?
