gary
- California
- Retired electrical contractor / general contractor
The photos in the link below reveal the catastrophic failure of a 4 year old GFCI receptacle mounted in a parapet wall surrounding the roof deck on a home located one block from the Pacific ocean. Assuming that it failed because of the corrosive marine environment, it could serve as the poster child for the importance of the use of the new weatherproof devices developed for outdoor use. It was part of a 20 amp circuit dedicated to the roof deck. The load terminals fed a single additional receptacle which also showed signs of considerable rust & corrosion on the back strap, mounting screws and connection screws. Neither outlet was being used at the time. I would be interested in knowing if any of you have seen similar problems with GFCI receptacles that were not simply due to arcing at a loose connection.
http://s265.photobucket.com/albums/ii217/ac6eg/Defective GFCI Receptacle/
