Michael Schneider
New member
If you have a 208/120,3 phase 4 conductor circuit and the circuit is unbalanced there is current on the neutral conductor. IF you use 3 individual breakers and one neutral, and you turn one breaker off there, will be current on the neutral conductor. If you are working on the circuit you shut off, there will be current on the neutral conductor. Is this correct and how do you prevent this from happening if it is correct. Must you turn off all 3 breakers to work on any of the 3 curcuits.
