has any one come across a 3 phase coffee maker with 3 hots a nuetral and a ground. amprage on the machine is 25.6- 28, i am lost do i need to hard wire or can i use SO cord with a twist lock, it would have to be a 5 wire plug or should i hard wire it with a safety switch.
Lets see the nameplate. I'll bet a small lunch that it ain't 3 phase.
Better get your lunch money ready cause if you Google 3-phase coffee makers a whole bunch of commercial size units come up. I saw one that is 12kW.
Three phases coffee tastes so much better than single phase coffee.![]()
Yes, but if the phase rotation is wrong, it will put you to sleep.Three phases coffee tastes so much better than single phase coffee.![]()
Read the manuals. They use 2 phases of a 208/120 volt system, 120 Volts or 240 Volts - all single phase connections.
3 Phase Coffee Machine:![]()
Is it 3 times better, or is it 1.732 times better?Three phases coffee tastes so much better than single phase coffee.![]()
Complications arose during an investigation of dietary influence; one research was unable to assimilate adipose tissue, and another was unable to consume tissue consisting chiefly of muscle fiber. By a reciprocal arrangement between the two researchers, total consumption of the viands under consideration was achieved, thus leaving the original container of the viands devoid of content.
Jack Sprat could eat no fat.
His wife could eat no lean.
And so between them both, you see,
They licked the platter clean
Interesting that it needs 4 wire with a ground for 3 phase or single phase. I suspect on single phase one wire isn't used. Without a diagram it would be hard to know if the elements are 3 phase or as the other posted stated .
