Presuming that these heaters consist ONLY of an infra-red heating element without say a fan, then yes they may be controlled by a lamp dimmer and I have often done this on small installations.
A 1KW lamp dimmer does not "know" if it is connected to a 1,000 watts of lamps or to a 1,000 watt heater.
What type of infrared heaters are these ? if the type that emits a red glow as well as warmth, then a high powered dimmer can be a good idea.
Adjustment of the dimmer will alter the brightness of the light, and re-assure the user that the desired effect is being obtained.
Thermostatic control is not ideal for such heaters as the on/off cycling of the red light is displeasing.
In the case of heaters that emit no light, then although a dimmer would work it may be needless complication, and thermostatic control or manual switching in groups might be simpler.
Remember that in the USA most dimmers are 120 volts, and many infra-red heaters are 208, 240, or 277 volt. Dimmers certainly exist for these voltages but are less common.
