Can Anyone Identify This Lug Manufacturer
DSamson
This lug came out of a Circle AW (B-Line) two-gang meter socket. The last installer over-torqued the screw and stripped it out.
I'd like to replace the lug if I can.
The lug part number includes the letter "R," which I believe must be for "reverse," because the tang and the block are opposite of a typical lug. I believe this is a standard lug that B-Line clipped the corners off of to make fit.
Note the company logo, middle left, a pole with a cable attached.
Would appreciate any help you can offer.
Thanks
You will never get the lug from a manufacturer.
They are made special for each OEM.
Your best bet is to buy a new socket of the same manufacturer and gut it.
