Brandon Loyd
When trying to call something by it's correct name. How would you define the difference between a Switchgear section, a Distribution board, and a Switchboard.
I think you need to clarify your question.
Are you looking for a "homework" type answer or some terms that are used in your locale?
For example if we only deal with physical size:
Distribution panelboards are normally wall hung and rarely exceed 12"d
Switchboards are normally free standing with typical depths of 24-48".
Switchgear requires front and rear access, on top of their common 96"depth.
I guess I am looking for more of a homework answer, like your reply. I would tell the salesman that a Distribution board is like a large wall mounted panel less than 12" deep. A Switchboard is a stand alone section with multiple-multiple pole breakers installed, maybe attached to other sections, no more than 24" in depth. And a switchgear section will be the largest peices of equipment typically with a blank pull section, maybe a meter section, then a distribution section that resembles a switchboard.
Can you think of any other generic homework terms to simplify these explantions?
