njtrombley
Hello all, I have a question that came up out in the field that I need some other interpretations on. We are wiring a nuro-care facility, 39 bed, and at each bed there is a medical gas panel that mounts in the wall and it comes complete with 3 - Hospital grade receptacles fed with normal power and 3 - Hospital grade receptacles on a generator panel. Also in the medical gas panel is medical gas (surprising I know). There are gas lines that patients get hooked up to for oxygen etc. These lines are pressurized by a compressor and a vacuum pump. Both the compressor and the vacuum pump are on the generator circuit. The generator is sequenced so that all the loads don't come on at once and stall the generator. The compressor and vacuum pump are part of the generator sequencing process and are delayed to be energized 15 seconds after the generator starts up. The way we did this is we put the compressor and vacuum pump on contactors and we are controlling the coil off the transfer switch because the transfer switch has control wiring that can be delayed. So the generator turns on, the vacuum pump and compressor are off until the transfer switch contacts close which pulls in the contactors for the vacuum pump and compressor.Now, to make a long story longer. The electrical room where the breakers are located for the vacuum pump and compressor are about 200' away from the mechanical room where the vacuum pump and comressor actually sit. We are putting the contactors in the mechanical room where the pump and compressor sit, but do we need a disconnect in front of the contactors in the mechanical room? The equipment has disconnects on them from the factory, but it's not a typical disconnect that would come with a gear package for instance (I will attach a picture). I know that the obvious answer is ask the AHJ, but I would like to know the facts before I do so.
