When you guys adopt the 2011 you will have to install the gfci somewhere accessible.
That's an interesting idea. I have always thought this was a ridiculous change to the 08 code, considering the height of the outlet, the opener is rarely unplugged, and rarely missing the ground prong.you can also install a dead front gfci ...
Accessible or readily accessible? Didn't they already need to be accessible before 2011?
That's a great suggestion for an upsell.However, if you had a deadfront GFCI in a proper weather proof location outside the garage, at least it could still be reset.
A tripped GFI is no big deal when you're inside the house, but if you are a school kid coming home and your only way into the locked house is the garage door code, it can be a much bigger issue. However, if you had a deadfront GFCI in a proper weather proof location outside the garage, at least it could still be reset.
Thats an interesting point you make, although i don't know of too many school kids who would think to reset a GFCI when the garage door doesn't work, but you never know. My thought was that if you have a tripped GFCI and a car parked underneath it, its gonna be quite a hassle to deal with.
That's probably true, but if so, fix the direct problem, not the ancillary one. Require more outlets in the garage so people are not forced to use an extension cord to reach an out of reach outlet.Rick, That receptacle is frequently used for other things as well. Many an extension cord has found its way to the garage door receptacle. Some become "permanent."
I did your search on several search engines, and with several variations....not a single story came up.Indeed. Google "Donnie electrocuted garage" or something like that to see one child that might have been saved.
You're missing the point. If instead of making the door opener outlet GFI, the code instead mandated the proper number of outlets in the garage in the first place, people would not be tempted to use an outlet that is otherwise inaccessible without a step ladder.You're foolin yourself if you think a single recep defeats a $.99 splitter.
