Especially if it's an old MH fixture. Newer electronic balasts like those in CLFs and their ilk are using better power supplies (assuming you don't use cheap Chinese junk) that are designed to reduce harmonics.It shouldn't be any more of a concern than the MH fixtures were and in reality probably less.
Roger
The input for a electronic ballast is a rectifier which results in non-linear current.Especially if it's an old MH fixture. Newer electronic balasts like those in CLFs and their ilk are using better power supplies
Conventional ballasts usually use linear components don't they?
Check out the link provided by Skeshesh.That is what I was thinking.
It's interesting but not really comparing apples with apples.Check out the link provided by Skeshesh.
Roger
But it is relevant to the OP's question.It's interesting but not really comparing apples with apples.
TBH, I think it is sales speak rather than of any technical value.They can. Here's a brief read: http://www.geappliances.com/email/lighting/specifier/downloads/Total_Harmonic_Distortion.pdf
