A length of twenty feet of EMT encloses only circuit conductors and is run on wooden supports across an outside roof to an AC unit. The roof space is narrow and the EMT is subject to physical damage and separation from being stepped on or tripped over by workmen.
Does Section 250.96 (A) of the 2008 NEC with its reference to the "use of supplementary equipment grounding conductors" allow an electrical inspector to request that an equipment grounding conductor in the form of a wire be run with these circuit conductors?
And if so, is it permitted to run this wire either on the inside or the outside of the EMT?
Thanks
Thanks
