Has anyone heard of low voltage lighting causing an arc fault breaker to trip? The lighting manufacturer told me that their lighting may cause an arc fault breaker to trip because of the electronics that run it? FYI this is low voltage track with three 12 volt, 35 watt lamps on it. They also stated that if the total wattage on the circuit exceeds 360 watts then that may cause nuisance tripping of the arc fault breaker. This simple does not make sense? Any thoughts?
