Open Neutral
- Inside the Beltway
- Engineer
....not sure if that Franklin spec is going to accept a simple Load Reactor (assuming here that you have a Franklin pump and need to make sure you follow their recommendations). You can contact a distributor for TCI (Trans Coil Inc) or MTE for load filters; regardless of where you buy them most of the ones on the market are actually made by one of those two companies.
Thanks. I have also found AquaPhase and Add-a-Phase as possible alternatives but need to do more reading.
