Has anyone installed an electric submeter on main switch gear before? What is the best way to make the voltage connections to the meter? Usually I would find a small subpanel and put a 15 amp breaker in and use that to power the meter and supply the voltage feed. In this case all I have is the main switch gear. Can you tap off the main bus bar somehow and go to fuses?
Thanks!
			Thanks!
