Above ground pools, 3-feet, and equipotential
ivsenroute
Florida
How do you, as a contractor address this issue when there is grass around the pool. How do you, as an inspector address this issue?
Assuming a pool that does not meet the definition of storable.
Assuming the 2009 IRC or the 2008 NEC applies?
I am curious as to the differences of opinion on this subject.
Does it make a difference whether or not the AG pool is storable? Assume a typical pool that does not meet the definition of storable pool.
Where is there an exclusion for AG pools?
If the pool is above ground and 42+" deep then an EPB is needed-- it is no longer storable. Storable pools 680 part III tells us to use parts I and III. The EPB is in part II. The definition of a storable pool is in part I
Grass around an above ground pool, spa or hot tub is still a perimeter surface in need of bonding.
The single conductor bare Cu 8 awg can be slipped into the ground after pushing a shovel down into the ground around the circumference of the pool.
Do you really believe that will do any good ?
Can you show me where the NEC requires epb for an above ground pool that is 36"deep?
Dennis it is not a 36 inch deep pool. He has told us twice that it is not a storable pool.
I think the 3' mentioned in the title is the 3' perimiter
A 3' perimeter pool?????? Sorry Bob I don't think so-- That's a 1' diameter pool-- even kiddie pools are bigger than that.
Well, I have to admit my feelings were a bit hurt when it seemed you thought I was goofy enough to think there was a pool greater than 42" deep and the diameter of a compound bucket ........ must be one of those pools for city homes. :grin:
Well I knew you had something other than what I was thinking but I could not place it. The 3' in the title threw me as all perimeter bonding is 3'.
Hey, you guys made me moderator, that's not my fault...:grin:
