dhalleron
- Louisville, KY
- Master Electrician/Senior Fire Alarm Technician
A lot of typing for a simple question.
I work with a guy that likes to lay his surface mount dryer and range outlets on the side. He says he does this because some cords won?t plug in because the cord sometimes would need to point down towards the floor and there is no room because the outlet is mounted on the baseboard with cable coming out of the floor.
I don?t like the looks of it mounted that way because he leaves the cable exposed as it comes out of the floor and turns into the outlet. Are there any particular brands of outlets or range/dryer power cords that are a problem when mounted on the baseboard with cable coming out of the floor instead of the wall?
The outlets I?ve seen have the ground prong on the side where the cable comes in (bottom if mounted on the floor) and the cords I?ve seen have the ground prong on the side opposite of the side the cord comes into the cap (bottom).
