Tricky Ricky
New member
1- Can you splice service wires inside the breaker panel? 2-If a panel is being feed from a breaker does the panel have to be a main lug or can it be a panel with a main.
If the panel is being fed from a breaker then the wires are not service wires, its a feeder.1- Can you splice service wires inside the breaker panel? 2-If a panel is being feed from a breaker does the panel have to be a main lug or can it be a panel with a main.
Overcurrent protection of panelboards can be within or at any point on the supply side of the panelboard. See 408.36 There are some exceptions.
